John deere grain drill model ?
/ John deere grain drill model ? #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
What model grain drill do I have I have no clue can't find a serial number on it it has 7 rows and mechanical lifted and dropped
/ John deere grain drill model ? #2
4' John Deere Van Brunt or at least looks similar.
/ John deere grain drill model ? #3
Only problem is JD didn't build a Model B in a 4 ft size. Must be a customized version. I know for sure because I assembled JD model B drills back in the 60's when I was employed at a JD dealership before I was reincarnated into an old crippled fart.
Yeah I'm needing to buy some parts for it that's why I was asking so it's a van brunt 4' u think
/ John deere grain drill model ? #5
Yes it's a modified JD Van Brunt model B grain drill
It needs all new seed cups and the road that drives them any clue where I could get them
/ John deere grain drill model ? #7
JD has the seed cups.
BB3592M Tube View/Update 43.06 USD requires cotter pin
BB3607M Tube ADD 29.62 USD
What are you calling the road that drives them? Do you mean rod?
Yeah the rod with the gear on it that actually turns in the seed cups
/ John deere grain drill model ? #9
Counter shaft or feed shaft? Feed shaft I'm guessing. FYI the feed shaft is fairly complicated to R&R. What distance are the feed openings apart(center-center) and how many openings on your customized drill?
To tell you the truth I'm not sure I haven't pulled it apart yet I will look maybe this weekend though
