john Deere Finish mower
/ john Deere Finish mower #1
bjess8
Bronze Member
SOUTH CENTERAL ,PA
GRAND L3130
I was using my JD 261 finish mower when the belt broke and got wound up on the pulley after taking it off and going to the JD dealer to get a belt I got back and there was oil all under the mower does anyone have any idea what this might, be so I can get started taking it apart?
/ john Deere Finish mower #2
I would guess the input or output shaft seals of the gearbox got damaged by the belt, OR the bearing went bad on the output side and that took out the seal and the belt.
/ john Deere Finish mower #3
I have the same mowing deck and I know the seal is gone on the output end. Any idea where I can find a replacement seal and more importantly, instructions for replacing it?
/ john Deere Finish mower #4
You can buy the seal through any JD dealer...
/ john Deere Finish mower #5
Thanks, I managed to find and order the seal on-line from John Deere. Now I have to figure out how to remove the spindle and replace the seal. I haven't taken one apart before and I can't tell what holds it together or whether it is just old and stuck. Any help would be much appreciated
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Winchester Themed Decorative Metal Sign (A61569)
Winchester Themed...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
UNUSED CFG INDUSTRIAL QK20R MINI EXCAVATOR (A62130)
UNUSED CFG...
