John Deere engine
/ John Deere engine #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Does anyone know of a good source for an engine for a 1976 John Deere model 4030???
/ John Deere engine #3
I think that is a 329. You might check combine and cotton picker territory, alot of those engines were in harvesting equipment.
Chuck M.
/ John Deere engine #4
I will second the link to Wenger's of Myerstown. Wenger's has a good reputation.
/ John Deere engine #5
Chuck M.
It is a 329. I'm not 100% positive, but I THINK the Deere 4400 combine has a 329. (Maybe 4420's too) You might have better luck finding one of them in a tractor bone yard.
/ John Deere engine #6
Yes, the engine is a 329 in the 4030 tractor. The 329 was used in the Deere 2840 tractor, as well as the 4420 combine. My information on the 4400 combine lists a 6-cylinder engine but the displacement as 239. That doesn't make sense. I am willing to bet that the first two digits are transposed in my source and the 4400 uses a 329, as well.
/ John Deere engine #7
Deere built a 239 Cu in diesel, but it came much later than when the 4400 combine was around. The 239 was used in the 2355 and 2555 utilities, plus a few other models. It was offered with a turbo on some higher HP applications. It was a further development of the 219 cu in engine that was in the 2520, 2030, and 2440 tractors. I'm 99.9% sure the 4400 combine used a 329 cu in engine.
/ John Deere engine #8
That is what I figured, too. I knew that the 239 was a 4-cylinder used in the later utility tractors. I guess that proof-reader for the Hot Line Farm Equipment Guide was thinking about other things when they got to the Deere 4400 combine.
/ John Deere engine #9
Some of the 6600 combines used the 329 as well. Some had the 404 also.
/ John Deere engine #10
Just curious, what happened to your engine? Is it missing, or just need a rebuild?
/ John Deere engine #11
6600's with DIESEL 329's? A new one on me. Seems like there were a few gas 6600's. I could be wrong about that too. I recall that being a Chevy 6-cyl. Gas engines were once popular in combines. Combine fires were once VERY common.
/ John Deere engine #12
Actually most all deere six's will go into that chassis. I wouldn't push it to much but that would mean the 404 as well as the 466 would bolt in. Now a good running 466 if taxed in that chassis would probably give you a lot of tranmission and rear end parts in an array you might not find desireable!
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
