John Deere engine
/ John Deere engine #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Does anyone know of a good source for an engine for a 1976 John Deere model 4030???
/ John Deere engine #3
I think that is a 329. You might check combine and cotton picker territory, alot of those engines were in harvesting equipment.
Chuck M.
/ John Deere engine #4
I will second the link to Wenger's of Myerstown. Wenger's has a good reputation.
/ John Deere engine #5
Chuck M.
It is a 329. I'm not 100% positive, but I THINK the Deere 4400 combine has a 329. (Maybe 4420's too) You might have better luck finding one of them in a tractor bone yard.
/ John Deere engine #6
Yes, the engine is a 329 in the 4030 tractor. The 329 was used in the Deere 2840 tractor, as well as the 4420 combine. My information on the 4400 combine lists a 6-cylinder engine but the displacement as 239. That doesn't make sense. I am willing to bet that the first two digits are transposed in my source and the 4400 uses a 329, as well.
/ John Deere engine #7
Deere built a 239 Cu in diesel, but it came much later than when the 4400 combine was around. The 239 was used in the 2355 and 2555 utilities, plus a few other models. It was offered with a turbo on some higher HP applications. It was a further development of the 219 cu in engine that was in the 2520, 2030, and 2440 tractors. I'm 99.9% sure the 4400 combine used a 329 cu in engine.
/ John Deere engine #8
That is what I figured, too. I knew that the 239 was a 4-cylinder used in the later utility tractors. I guess that proof-reader for the Hot Line Farm Equipment Guide was thinking about other things when they got to the Deere 4400 combine.
/ John Deere engine #9
Some of the 6600 combines used the 329 as well. Some had the 404 also.
/ John Deere engine #10
Just curious, what happened to your engine? Is it missing, or just need a rebuild?
/ John Deere engine #11
6600's with DIESEL 329's? A new one on me. Seems like there were a few gas 6600's. I could be wrong about that too. I recall that being a Chevy 6-cyl. Gas engines were once popular in combines. Combine fires were once VERY common.
/ John Deere engine #12
Actually most all deere six's will go into that chassis. I wouldn't push it to much but that would mean the 404 as well as the 466 would bolt in. Now a good running 466 if taxed in that chassis would probably give you a lot of tranmission and rear end parts in an array you might not find desireable!
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
