John Deere carb
   / John Deere carb #11
It's not always easy to "see" the fault. There may be a small tear in the diaphram, it may have deteriorated near the sealing edge(s) or the spring may have broken. Last time I bought the kit I think it was $3.00.
   / John Deere carb
Well, thank you for helping me out with this!!
   / John Deere carb #13
Sorry it took me so long to reply. I was away from my computer for a while.
The fuel pump kit is a good deal for preventative maintenance. Not very expensive and really quite easy to do. You should note that the fuel pump pumps gas from the tank to the carb. It has NOTHING to do with getting it into the combustion chamber...
The carb is a little more complex. There could be many things wrong and one of the best ways to determine what is causing your problems is a full disassembly of the unit.
What I usually do for an engine that was running great but isn't now is to take the carb off and disassemble it (remove the bowl, needle, float, all set screws, etc...). Put the whole mess of things in a container with some carb cleaner or deisel fuel. Carb cleaner generally works better, deisel is cheaper. Let it soak for a while.
After all the crud is gone, you can usually see any parts that are worn. From there, I replace anything that looks worn and re-assemble. After adjusting it, I usually find the problem is gone. Carbs are tricky. Any little piece of dirt around the needles can send things into a tailspin.
Also, I would re-build rather than purchase. A full carb re-build kit is probably MUCH less than a new carb and you're mainly paying for the body when you get a new one. Chances are, that's the one part that will never break.
Take your time and if you have questions, post some pictures if possible with descriptions of what is wrong. I'm sure someone here can help you through it!
Have fun!
Mark
   / John Deere carb #14
FYI:
I looked at JD Parts online and found the kit. It includes:
- O-Rings and Seals
- Bowl Gasket and Float Pin
- Needle Valve
Total cost is $37.99
Cost for a new carb through JD is $120.00
These prices may or may not be exact, but are very close.
Good luck!
Mark
   / John Deere carb #15
yup,
agree with Mrwood,
all the carb cleaner in the world can't get into the tiny passageways inside that carb. Tear it down, and soak it good. Most shops have a tank with solvent that is pretty good
at getting everywhere those little spray cans can't.
keep us posted
/forums/images/graemlins/cool.gif
2015 JEEP Compass (A50324)
2015 JEEP Compass...
One pallet of tree stands (A50860)
One pallet of tree...
Craftsman Lawnmower (A50860)
Craftsman...
71066 (A49346)
71066 (A49346)
2022 Spartan SRT-XD Zero Turn Mower (A50860)
2022 Spartan...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
