John Deere 990
/ John Deere 990 #1
lazy b farms
white deer texas
6640 see
Needing some help on my 990. For some reason the crankcase is filling with Diesel. Drained nearly 2 and a half gallons out today. Where could it be coming from? Any help would be greatly appreciated.
/ John Deere 990 #3
There are three possible routes for fuel to enter the lubrication system
Fuel lift pump – The diaphragm can split providing a route for diesel to enter the engine crank case.
Injector pump – Injector pump shaft seals have been known to fail.
Damaged Injectors – Leaking injector nozzles during periods of inactivity can drip their contents into the cylinder which then runs down between the piston and bore into the sump.
/ John Deere 990
Finally got back on it this afternoon and removed the fuel pump and injection pump. Planning on taking them in to have checked out. I am wondering though if tractor starts and runs good could it still be an Injector? Starts right up every time and smokes very little.
BODY LOAD TANK (A67714)
BODY LOAD TANK...
2024 KUBOTA SVL97-2 SKID STEER (A65056)
2024 KUBOTA...
Detroit Diesel 3 Cylinder Power Unit (A64912)
Detroit Diesel 3...
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
10' Fork Extension (A64912)
10' Fork Extension...
2025 Electric Cart (A66738)
2025 Electric Cart...
