John Deere 855 PTO Engagment Magnet
   / John Deere 855 PTO Engagment Magnet #1
Dan Smith
John Deere 855
I have a JD 855 and whether I am mowing or blowing snow the PTO egagement lever pops down 0 like the magnet is not holding it - can be reset and then it works for awhile.
   / John Deere 855 PTO Engagment Magnet #2
Welcome to TBN. :)
   / John Deere 855 PTO Engagment Magnet #3
Welcome to THE forum.
I'd look for a safety switch cutting the PTO off. Seat switch would be my first guess. The system may believe you are off the machine and cutting off the PTO.
Seat safety switch checks good with an ohmmeter and problem persists with seat switch temporarily defeted. Anyone know about lubricating the PTO magnet linkage and an easy way to get to it?
   / John Deere 855 PTO Engagment Magnet #6
Welcome to TBN!! You might want to re-post your question to the JD forum. I bet you will get lots of responses.
   / John Deere 855 PTO Engagment Magnet #7
Might be the electronic box right under the PTO lever or the connections to it.
I would try checking the connector first. This box introduces a small delay in the safety switches so the PTO does not cut on and off every time you hit a bump and the seat goes up.
Here is one for sale so you see what it looks like: JOHN DEERE 655 755 855 MISC. ELECTRICAL BOX | eBay
Otherwise, maybe the electromagnet has a life and yours is going bad? I don't have much experience with that.
   / John Deere 855 PTO Engagment Magnet #8
Hey Dan! Welcome to TractorByNet! :D I have moved your thread to the John Deere Owning/Operating Forum. You will have better luck finding assistance there. :thumbsup:
   / John Deere 855 PTO Engagment Magnet #9
Dan , there is a spring wire that holds lever in the forward/engaged position that mounts just on the underside of the dash. Is yours broken off by chance? Mine was and I had to replace it, but fortunately it is only a couple bucks. It solved the problem for me
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
