John Deere 855 Drive Pedal Problem
   / John Deere 855 Drive Pedal Problem #1
DougMac128
UK
Various Japanese Brands
Hi
I have a JD 855 hydro tractor. The drive pedals stick and do not return to neutral. If you do not set drive to neutral and get off the tractor it takes off. Any ideas. Tractor has done 2300 hours and is in generally fair condition.
Kind regards
Douglas
   / John Deere 855 Drive Pedal Problem #2
First thing is to look for any binding of the linkages and lubricate!
   / John Deere 855 Drive Pedal Problem #3
Run the front of your tractor up on some ramps.
Look up through the hole you will see in the bottom of the transmission case housing.
You will see a fork that a bearing rides up and down the side of.
The bottom of the V is neutral, you will notice a bearing, if this bearing is not free the transmission will not go back to neutral. This bearing and the pedal linkage of the two biggest causes of pedal trouble.
I have a PDF copy of the John Deere technical manual if you would like a copy. If so shoot me your email.
Roy
All linkages are lubricated and working. You have to apply substantial foot pressure to increase movement speed whether in forward or reverse.
Many thanks for advise and offer. I take it this is a standard bearing. Email douglas@rfidsystems.co.uk.
   / John Deere 855 Drive Pedal Problem #6
You can find them aftermarket, but I don't remember the number to use
Manual link on the way in a moment
   / John Deere 855 Drive Pedal Problem #7
deere number is a AM102726 ( takes two) should cross to a 6082RS bearing
Joe
Many thanks. I will strip it down and check.
2121 (A51244)
2121 (A51244)
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
