John Deere 855 and 856
   / John Deere 855 and 856 #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I was looking around on Tractor house.com and noticed there was some John Deere 856's listed. Best I could tell the only difference in it and a 855 was the number. Does anyone know anything about them. Are they identical to the 855 or are they different.
   / John Deere 855 and 856 #2
I think the 856 was a golf and turf model , came with wider tires , and scv was an option. Somthing like that . I worked on one once and it was idenical to an 855.
   / John Deere 855 and 856 #3
If you search for it on JD Parts, it comes up along with the 855's so I guess it pretty much the same...I have never heard of before though...
   / John Deere 855 and 856 #4
An 856 was a 855 that had the three point hitch removed. Then a sub-frame was mounted under the machine and out the back. Reel mower heads were mounted to to the frame and driven hydraulically from a pump set mounted on the pto. Not a bad mower in it's time, but most have been stripped down and converted back to regular CUT's. You still see the 856 decals one one now and then.
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
Genie GTH-644 (A50490)
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
