John Deere 850 tractor, what is this control for?
   / John Deere 850 tractor, what is this control for? #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Can anyone shed some light on what the hyd control under the seat is for on a John Deer 850? It is the one with a rollpin in a shaft, looks to adj flow or???
   / John Deere 850 tractor, what is this control for? #2
That is the rate of drop valve. Put something heavy on the three point hitch,and adjust that valve so it drops slower when you lower it.
If that is the rate of drop control, what is the large flower shaped knob in the lower left corner of the 1st picture for?
   / John Deere 850 tractor, what is this control for? #4
I had an 850 for 27 years. The “flower” shaped knob is the rate of drop for the three point. The lever you are referring to is the draft (at least according to the owner’s manual I had)
   / John Deere 850 tractor, what is this control for? #5
The one with the knob is the Stop valve which you would use if you wanted to lock the three point hitch up.I never have found a use for it yet,so always leave it unscrewed all the way out. the book says Important: 1. Do not raise control lever when hydraulic stop valve is closed. 2. Do not lock rockshaft in its highest position. 3.Open valve completely when it is not in use.
   / John Deere 850 tractor, what is this control for? #6
See if this helps-
Thanks for all the responses. So much for standardization as all my other tractors the flower knob was rate of drop. Now I know it is the hard to get to roll pin!
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
John Deere 1025R (A53317)
John Deere 1025R...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
