John Deere 850 crack in water jacket
   / John Deere 850 crack in water jacket #1
mgsolakis
Ontario, Canada
Case 446
Is a crack in the outer block water jacket fixable. I have heard of people welding it but can the whole part be replaced or is that a whole engine replacement?
   / John Deere 850 crack in water jacket #2
Post a pic if you can. Welding cast is tricky, but it can be done. It depends on how big, and where. I had a crack in the rear end housing of a Farmall H. I sanded it down, cleaned it with lacquer thinner and patched it with JB Weld. No Leaks for 20 years!
Ask a good welding shop
   / John Deere 850 crack in water jacket #3
It really just has to hold the coolant pressure correct? I would try and weld it my self but of it still leaked I would be giving it a nice coat of JB weld. I can put up with a bit of coolant leak..some people cant.
   / John Deere 850 crack in water jacket #4
Here is the pinning method.
   / John Deere 850 crack in water jacket #5
   / John Deere 850 crack in water jacket #6
   / John Deere 850 crack in water jacket #8
I can and have welded water jackets before. Usually on engines from vintage things that can't be replaced. Done right it can be successful. I am not sure I would consider it a DIY job though.
   / John Deere 850 crack in water jacket #9
Yup, agree with you deeman. I've welded a few using Nirod 55, they were successful but could have just as easily been a waste of time. It's a cold welding process where you don't let the piece get warmer than you can hold your hand on it and peen it after each short bead.
Epoxy will work sometimes but worst is if it doesn't then you have a bunch of crad you have to clean off before you can attempt to weld it.
As was said, post a couple of pics.
Side note, worse than that is someone who tries to repair their aluminum boat with silicone and then brings it to you asking if you can fix it after.....not fun............Mike
   / John Deere 850 crack in water jacket #10
Have you tried the cast iron cement for wood stoves??
works great on the 454 exhaust manifolds
willy
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
