BleedingOrange
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 2,760
- Tractor
- Kubota BX 2370
Before you go ahead with any kind of repair, have you been able to figure out why the block cracked, in the first place ?
Yes, and/or foam on the dipstick.No how do you check this? Would it be evident in the engine oil as a milky substance?
After engine has set not running for about 24 hrs loosen engine oil pan plug about 3 turns then wait a few minutes for liquid to escape between plug & pan threads. If coolant is present in pan it should leak out before any oil drips out.No how do you check this? Would it be evident in the engine oil as a milky substance?
