John deere 820
/ John deere 820
Any thoughts on what's a good size bush hog for this tractor?
/ John deere 820
Well tractor is running great. Only problem I have with it now is that it won't start with key. All it does is clicks. Battery is good and starter was just rebuilt. If I jump starter off with screwdriver it will start. I got 12 volts at the starter.
/ John deere 820 #44
Inability to start with key switch but able to jump across solenoid post to start engine is an indication of voltage/amperage drop in either neutral start switch,ign switch,start circuit wiring or one or more of the list. Simple solution is add starter relay that JD installed on later model tractors.
RE42993 STARTER MOTOR KIT
/ John deere 820
When I jump the starter it didnt start right away. The solinoid clicked bout 4 times befor starter engaged. Starter worked fine before no problems. The shop that rebuilt it said they will check it out since it has a year warranty.
/ John deere 820
Brought starter to repair shop. They tested it and the solinoid is bad. Hope to have it back today or Tom.
/ John deere 820 #47
Glad you got it running! Had a similar problem turned out to be clutch linkage problem due a "heat and beat" repair made by an employee and not properly adjusted. A new connecting rod, two clevises, and an adjustment or two and all was and continues to work properly. Hope you have yours worked out by now.
/ John deere 820
Well I'm back. The 820 is running ok. Cut about 6 acres with it. The only problem I have is the engine has a miss at certain rpm. Then the injector pump started leaking. Im trying to find someone in my area to reseal it. Hope once I get that done that will solve the miss. Other than that everything else works great. It has a whole lot of power. It is a little mule.
/ John deere 820 #49
I'll bet the leak on inj pump is on the cover that the throttle shaft protrudes out of. Correcting that leak(if I guessed correctly) won't stop an engine miss.
/ John deere 820
It is not leaking from there. I kno it won't stop the miss just trying to figure out what it could be?? It runs great at certain Rpms but espically at idle it's worse. When I run at Max rpm it's runs like a champ. Just looking for some ideas.
/ John deere 820 #51
Have tried using any diesel fuel conditioners/inj cleaner fluids?
/ John deere 820
Yes I have. When I crack open injectors there is a noticeable change on each one. Not sure what else to check?? Everything works like its supposed to. It don't run hot. Like I said it just at certain Rpms. I'm stumped!! Fuel pump is new. Filter is new.
/ John deere 820 #53
About the only thing left to do is pull the questionable injector and have it tested or replace it.
/ John deere 820
That's what I was thinking. I do have one injector so guess i will try each one to see if that cures the problem. I'm hoping its not a compression issue or valve issue. It has way to much power for that to be it.
/ John deere 820
Well found problem with miss I'm having. It's the injecter pump. It has a stanadyne pump on it. I found a diesel repair house that will rebuild and reseal for 450. Going bring next week and hope I'm done working in this thing
