John Deere 790 front loader problem
/ John Deere 790 front loader problem #21
The 790 initially had a 70 loader, then a 419 and now uses the 300x.
The 67 loader has a mounting system quite a bit different then the mounts used on all three loaders used on the 790, If the 67 loader comes with the correct mounting brackets, you could see if they use the same hole pattern.
However I think, if I were you, I'd look around for a loader that had been mounted on a 790. I've seen 70 loaders on CL occasionally. I've never seen a 419 loader on CL.
/ John Deere 790 front loader problem #22
I know this is old thread maybe someone can help me too I mounted a loader on my 990 the only way I can get loader to work is raise the 3pt hitch and turn knob to closed center this kills the rear lift but loaderworks as should open valve back up loader stops but lift starts back what seems be my problem thanks poorchop
/ John Deere 790 front loader problem #23
Do you have a dual SCV that you have the FEL connected to, and is it a Deere loader?
Pics of what you have would help.
/ John Deere 790 front loader problem #24
Been there yes bought loader off a junk 990 I got the valve joystick everything off it the 2 hard lines bolt into right side of rockhouse valve the returnees to side transmission it was jd factory set up
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
