John Deere 790 Electrical Problem
/ John Deere 790 Electrical Problem #1
BigMomma
NJ
JD 790
Looking for ideas/help. I have a JD 790 - which is a great machine - ~550 hours - very well maintained and has always run great. It worked perfectly on Saturday - went to start it yesterday, and it is totally dead. Not even lights - nothing happens when you turn the key (guages,etc). I am trying to diagnose and fix the problem.
The battery was old, but still holding charge - nontheless, I replaced it. Cleaned the ground, checked the fuses, all safety switches are in their proper starting position. Chatted with a local used equip dealer and he didn't have any other ideas.
I'm perplexed - any ideas?
Thanks for the help.
/ John Deere 790 Electrical Problem #2
did you check the MAIN fuse located near the starter...its like a 60 amp fuse or so.
/ John Deere 790 Electrical Problem #3
Some tractors also have a "fuse wire". That one is harder to find and can look o.k. on the outside casing, while the insinde wire is burnt off, thus acting as a fuse.
Thanks for your help and quick replies. The Main Fuse was fine, but glad to know about that one.
I found the problem to be the Ground CABLE. It looked fine, but surprisingly was corroded inside the casing - never seen that. I replaced the cable and am up and running.
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
John Deere 5525 (A60462)
John Deere 5525...
40ft Shipping Container (A64194)
40ft Shipping...
86 (A63290)
86 (A63290)
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
