John Deere 755 Rear main seal
   / John Deere 755 Rear main seal #1
joshua27
Jasper, TN
John Deere 755
I think the rear main seal on my JD 755 is leaking. The tractor drips a small amount of oil on my garage floor after heavy use and the only place I really see any "wet" oil is around the flywheel. My question is, would it be possible to replace this seal without pulling the motor? It looks to me like if I remove the battery/battery tray, exhaust and drive shaft that I could get it to it from the top without having to remove the motor. This would be ideal for me since I don't have an engine hoist and would have to borrow one if necessary to pull the motor.
   / John Deere 755 Rear main seal #2
you're gonna split it!, easily done with some care and two floor jacks, I have a PDF of the tech manual if you want to read up on it.
Shoot me your email if wanted
Joe
This tractor has a frame with an engine sitting in motor mounts along with a drive shaft hooked to the rear HST drive axle.
When I rebuilt my 1050 I split it because the engine and tranny ARE the frame but this 755 is nothing like that.
I guess to me splitting a tractor would be in the traditional sense where as with this newer style it痴 more like pulling an engine out of a car.
(3) Bicycles (A50860)
2006 International 4400 LP Ambulance (A50323)
2006 International...
2014 Infiniti QX60 AWD SUV (A48082)
2014 Infiniti QX60...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
2007 Chevrolet Impala Sedan (A48082)
2007 Chevrolet...
2016 Nissan LEAF Hatchback (A48082)
2016 Nissan LEAF...
