John Deere 755 loader question
/ John Deere 755 loader question #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Hey all. Looking to buy a JD 755/855. I think either would suffice for my needs. However, I cannot locate one where they dont want you to rob a bank for it. However, I did find a JD 40 loader. Would a 40 loader fit a 755? What is the difference between the 40, 52 or 70 loaders?
/ John Deere 755 loader question #2
No, not without too much welding and fab. Plus that loader is made for smaller tractors.
If cost counts, I suggest you widen your search beyond JD.
Luck, rScotty
Luck, rScotty
Thanks. I kind of figured it would be too small and need some modifications. Just not many 755/855 around my area for sale. There are many that have no loader, and seen the 40 loader for sale too. Thought one could make one from both. Ohwell, the search continues.
/ John Deere 755 loader question #4
I had a JD650 to which I installed a JD60 loader. The loader physically fit, though required hydraulic connection changes to work. Though I could remove that loader from the tractor, it was a lot of work. Happily I had little need to do that. From that effort I learned to get a loader which was intended for use on the tractor you intend. There are too many peripheral factors which can eat up your initial installation time, and then later re n re time. The other factor I noticed with the 650, and other compact tractors with loaders was the stiffness of the loader from on the tractor, particularly when it was a removable loader. Though I used the primary mechanical connection of the loader frame to the tractor as JD designed it, it was not a very stiff loader on the whole. The two vertical arms would bend in and out as a load was lifted, or you pressed the loader down. Not unsafe, but a nuisance. I did consider doing away with the removability capability entirely, and just welding the whole loader frame together to bolt onto the tractor, but I was worried that that would just transfer the flexing loads somewhere else, and it would break. Them that bends don't break! Ultimately, and very sadly, I lost that tractor in a fire, and the insurance company very kindly bough my a new JD1025R. It's loader design is far superior to that of the 650, and the several things I did not like of the 650 loader arrangement are well resolved with good design.
If you're getting a deal on the 755 and loader fair enough, but unless it's a deal, I'd certainly buy an newer JD compact tractor with a newer loader instead!
/ John Deere 755 loader question #5
Buy one WITH a loader already fitted to it with controls. Used tractors like these have high prices because they are in demand: no electronic B.S. ("hey whats code 41.2.3a mean"), no DEF, clutchless, trailerable, plenty of H.P. even to cut & bale hay, fit in a garage, easy to operate & service by suburbanites, AND, our watered down money makes their values proportional. They go for under $12k around here. Yours will be worth $24k in 5 years with current inflation.
/ John Deere 755 loader question #6
I agree with ZZ, they are pretty desirable around my area as well. They don't come up for sale very often, and are a little pricey when the do. There is a reason for that.
Doug
/ John Deere 755 loader question #7
There's a few on Machinefinder.com with belly mowers and loaders. Various prices from $5000-$12,000.
/ John Deere 755 loader question #8
A 70a loader would fit, and be original. The frame mounts are what is critical. My 855 came with a JD 420 loader (quick connect style), and I really love the tractor. No new electronics or DEF crap. If you're on FB, there's a group there just for the x55 tractors. Often see loaders and (more often) complete tractors listed for sale there.
/ John Deere 755 loader question #9
Seeing a 70A loader for sale, presently on a Deere 855, if that helps anyone. Waupun, WI on CL for $4800
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A65643)
2008 MOTIV...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
Landhero 12-Ton Hydraulic Shop Press Machine (A66408)
Landhero 12-Ton...
New 4 Seater Electric Golf Cart (A65579)
New 4 Seater...
