John Deere 755 engine stopping
/ John Deere 755 engine stopping #1
robbridgland
Bucknell UK
John Deere 755
Hi
My John Deere 755 suddenly the engine started to stop
Would restart for 5 seconds then stop again
Looked and saw solenoid to fuel shut off was closing
If I hold it open engine runs fine
Any idea of causes. Ignition switch isn't brilliant so I am going to get replacement
I am an Engineer and have multi meter and was going to check seat switch
Any other pointers gratefully recieved
Otherwise great little tractor bought used. if it ever goes badly wrong I am going to have to buy new or have wife leave me
/ John Deere 755 engine stopping #2
Check for voltage to the solenoid after it stops. Probably a bad coil on the solenoid, or at least thats what it sounds like.
/ John Deere 755 engine stopping #3
Check the power supply to the solenoid coil. There may be a loose wire, etc thats going "open circuit" once the engine starts that allowing the solenoid to close the fuel suppply.
/ John Deere 755 engine stopping #4
The fuel stop solenoid on my 5300 failed during a day I was discing food plots for a friend. Had to open it up and take the plunger assembly out. Ran fine but had to stop the engine by stalling it with brake and clutch. Seemed it was a weak design.
Went to solenoid found loose wire on connection problem solved . You saved me hours many thanks
Very much appreciated
Rob
KingKutter XB (A64126)
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
