john deere 755 creeping
/ john deere 755 creeping #1
robbridgland
Bucknell UK
John Deere 755
Hi everybody
I have a john deere 755 which creeps when I take my foot off the forward or back pedal
I have the manual to read but cannot see any easy adjustment
Other owners have same problem
any easy fixes
Thanks
rob
/ john deere 755 creeping #2
Most hst machines have an adjustment procedure described in the owners manual to in effect center the pedal.
Before jumping into that you need to ensure that the linkage is not binding from lack of lubrication.
Dave M7040
Hi everybody
any easy fixes
Thanks
rob
Hi That makes sense. Off I go with oil can Many thanks Rob
/ john deere 755 creeping #4
Look up through the open section in the center bottom of the case at the pedals. You will see a pair of little bearings riding in a V, that is what brings the hydro back to neutral. If they are dry or sticking, you get creep.
/ john deere 755 creeping #5
My 755 had a creeping problem and the problem was a roller bearing that rides on the V mentioned above. Applying grease to the surface helps for a short period of time, but eventually it resumes creeping.
The bearing is hidden up in there and is a bear to get you, but you can do it from under the machine. There are a couple spacers up in there that you'll need to watch for too.
Jason
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
APPROX. 5000bu GRAIN BIN (A64277)
APPROX. 5000bu...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
3ft Metal Chevrolet Tailgate (A65583)
3ft Metal...
