John Deere 755 compact tractor
/ John Deere 755 compact tractor #1
BLC755
blc4570@yahoo.com
Fuel shutoff solenoid wont stay in! To keep tractor running ?
I used 755 the other day! Ran fine like usual!! 1986 I've had it 20 years ! Went to use it next day! Wouldnt start i noticed fuel shutoff wasnt retracting. So i knew to push it in started right up! But a little imconvenient to take side panel off every time to start it! So i took off solenoid noticed black wire was broke off going into solenoid. So figured this was problem! Bought a new solenoid installed it!!! Well now it starts but doing exactly the opposite ! Starts hold in coil works but wont stay running ? Hold in coil only uses 1amp fuse is good ! Any ideas on what problem could be? Thanks
Well 138 views but no answers ! I got it going i installed new solenoid and adijusted linkage same as old one ! I unhooked linkage cranked on it it sucked right in !!! Old solenoid must have had wear on it ! I adjusted new one starts right up! I guess probably wasnt letting it go in far enough is my guess! I guess you'd call it determination! American ingenuity or just tinkering with it till i figured out to get it running !!!Anyways thanks for all the views!!!!
/ John Deere 755 compact tractor #4
We all knew you could figure it out.. :D
Ha ha ha what is it serendipity!!!! Discovered by accident!!!!!
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
2018 International LT Automatic Day Cab (A62613)
2018 International...
