Apr 22, 2018 / John Deere 750 Leaking oil #1 Mountaineer Deere New member Joined Sep 28, 2011 Messages 11 Location West Virginia Tractor 1983 John Deere 750 My John Deere 750 is puking oil out the blow by tube any ideas?
Apr 22, 2018 / John Deere 750 Leaking oil #2 T TimberHole Platinum Member Joined Jul 17, 2017 Messages 524 Location Missouri Tractor JD9504WD w/ 75 Loader, JD345, Bobcat S150 Blow by? How many hours?
Apr 22, 2018 / John Deere 750 Leaking oil Thread Starter #3 OP Mountaineer Deere New member Joined Sep 28, 2011 Messages 11 Location West Virginia Tractor 1983 John Deere 750 about 730
Apr 23, 2018 / John Deere 750 Leaking oil #4 T TimberHole Platinum Member Joined Jul 17, 2017 Messages 524 Location Missouri Tractor JD9504WD w/ 75 Loader, JD345, Bobcat S150 Sounds like cylinder issues. Have you done a compression test and a leak down test? I assume the 750 has an oil filler cap on the valve cover. If so, remove with the engine running and see if you are puking an excessive amount of pressure.
Apr 23, 2018 / John Deere 750 Leaking oil #5 S Stimw Elite Member Joined May 6, 2005 Messages 2,605 Location N. E. Florida How is the oil level? Is the oil white/milky?
