Oil & Fuel john deere 650 not starting
/ john deere 650 not starting #1
kpocho
finally got the fuel lines bled but still not starting. I am getting plenty of fuel to the injectors and a lot of black smoke but no ignition. If anybody has any ideas i would sure appreciate the advice. Grass is getting kind of tall need help!
/ john deere 650 not starting #2
Air filter clean? If you're not sure, probably best to replace it.
Will the tractor start with another battery (starter might not be cranking fast enough)?
If neither of those helps, it's probably time for a compression test or cylinder leakdown test. That would give you a good idea if the valves are set correctly or if there is wear in one or more cylinders(650 has 2 cylinders, right?).
Another possibility is it's slightly out of timing
/ john deere 650 not starting #3
Pull it with a vehicle in a low gear to get the motor up to a median speed (rpm). That should get the compression up enough for it to light off. Be wary when it starts to run so you don't ram into the tow vehicle.
the air filter is clean and the starter is cranking fast enough. this is only the second time this has happened. after the first time i let it sit over night then tried the next morning and it started right away. Both times i had it running already that day and i just lowered the throttle to much and it died, then it wouldn't start.
/ john deere 650 not starting #5
WHAT! A JD650 not starting, unheard of. Sorry I have not a clue why. I have a soft spot in my heart for the JD650, had one for 20 years or so.
/ john deere 650 not starting #6
It seems odd to have alot of black smoke during cranking. Black smoke usually comes under heavy load, lack of air or excess fuel. Possibly you have a sticking rack in the fuel injection pump or maybe clogged exhaust? Try removing the muffler and see if it starts. Maybe a baffle in the muffler is loose and moves around causing excess back pressure.
/ john deere 650 not starting #7
I had a similar instance with an 855. A Deere mechanic advised me to remove the air intake hose and put a rag over the intake with a hose clamp. Spray the rag with a few shots of gasoline, then crank it and see if it starts. If it does, runs for several seconds and then stops, all of the mechanicals (compression, valves, etc. are good) and you have a fuel problem (supply, lines, filter, injector pump or injectors). My problem was a leak in the fuel filter gasket that let air in but didn't leak any fuel that you could see.
/ john deere 650 not starting #8
Oooh. Easy on the rag over the intake. I've seen 'em suck the rag right in on startup before. And I mean WAY in!:(
/ john deere 650 not starting #9
I had the same problem and a back-woods mechanic figured it out for me so I maybe off in my description, but there's an electromagnetic PTO switch that might be bad. I think its under the seat and it controls the PTO safety. If its bad the machine won't start as it thinks the PTO is engaged.
/ john deere 650 not starting #10
It shouldn't even crank if that was the case.
/ john deere 650 not starting #11
Get it started(whatever it takes) Put a half pint of any ATF in a full tank of fuel and run it through-will fix a sticky rack(if not completely frozen). Modern diesel does not have enough lubricity for older tractors! You'll have to add lube to every tank
/ john deere 650 not starting #12
My 650 was always hard to start until I started mixing Power Service in the fuel,a little boost in the cetane might help.Also it is gravitey fed,anything less than half a tank and it wont pick up prime.
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
