John Deere 650 Clutch replacement
   / John Deere 650 Clutch replacement #1
Wreckaboy1
Merrimack NH
John Deere 650
Hi
I have a mid 80's John deere 650 , 4wd tractor with bucket loader. I'm in the process of replacing the clutch. I've got a copy of the service manual and have followed the instructions for splitting the tractor. I can only get the tractor spread apart about an inch. I have everything disconnected, and the drive shat is not seized on the slip joint for the splined shaft. Does anyone have any recommendations? I have the front supported via an engine hoise and a floor jack for the rear.
Joe
603-365-5219
   / John Deere 650 Clutch replacement #2
You might have a "bind" in the shafts. It may be a little too high or too low. You need to play with the hoist and floor jack to try and eliminate any bind. Raise or lower a little and try to get it to split more.
2016 Ram 5500 4x4 Altec AT37G 37FT Bucket Truck (A50323)
2016 Ram 5500 4x4...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2006 International 4400 LP Crew Cab Fontaine Ambulance (A50323)
2006 International...
8ft Fork Extensions (A50322)
8ft Fork...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
