John Deere 6410 tractor won't start
   / John Deere 6410 tractor won't start #1
weezy22
hampton, VA
I have a 2001 6410 tractor that won't start all of a sudden. It was fine the day before. My first guess was the starter went bad, but after checking to see if the solenoid was getting power while turning over the key I realized that it wasn't getting power. My next step I checked all the fuses and swapped relays, still nothing. Which led me to the neutral start switch. I replaced it and still nothing. can anyone help me out please?!!!!
   / John Deere 6410 tractor won't start #2
"won't start" Does that mean the engine won't turn over? or the engine turns over but the engine won't start?
:welcome: to TBN
Hang tight, as good help will come along.
@ beenthere the starter will not engage. when I turn the key to start it, it does nothing. Battery is only a month old and has plenty of juice. I'm getting power to the starter, but when I turn the key I'm not getting power to the white wire going to the starter solenoid
   / John Deere 6410 tractor won't start #5
Sound like neutral start swith or relay doesn't have continuity. Is trans in neutral & pto off?
Yeah it's in Neutral and the PTO is off. I have replaced the Neutral start switch, ignition switch and the starter solenoid mounted to the block. I have no schematic or troubleshooting tree for the this tractor and been scouring the internet trying to find something that will help.
   / John Deere 6410 tractor won't start #7
Check operation of parts key 10 the starter relay
   / John Deere 6410 tractor won't start #10
Cab or open station?
Starter relay for cab is on left side of engine.
Starter relay for open station is behind dash.
2017 Kubota SVL75-2 (A50120)
2017 Kubota...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
More info coming soon! (A50322)
More info coming...
2010 Toyota Corolla LE Sedan (A50324)
2010 Toyota...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
