john deere 6410 engine wiring issues
/ john deere 6410 engine wiring issues #1
legiog
john deere 6410
Hi,
I have the jd 6410 engine rebuild and the engine loom has some issues as the tractor does not start. Before it was starting OK, now the dash bord is lit up and when I tried to start the engine will switched off, i did replace the loom cabin plug L102313 {no. 9 in the photo} as the previous one was damaged and, probably i did not add the pin correctly to the plug, so does anyone have a L102313 scheme as which number should connect to which component please?
  • Screenshot 2024-08-01 at 12-17-50 AL153703 Engine Wiring Harness Shop.Deere.com.png
