John deere 5720
/ John deere 5720 #1
Fred au
john deere 5720
My steering requires more effort than it used to, and this happened over a 2 hour period. John deere dealer has done extensive testing and told me that the orbital steering unit needed to be replaced. I replaced it under there advice with no improvement. I have also kitted the priority valve finding nothing visibly wrong. have pulled one hose off the steering cylinder and checked for bypass. Does not matter weather at idle or revs the steering is tight. nearly like a phantom pressure is causing this issue to the steering unit. Is there a 5720 expert out there as I am tearing my hair out and have spent $3500 au to date. Don,t believe there is an issue with the return oil via brake master cylinder. This machine has only done 2000 hrs and has been very well looked after.
/ John deere 5720 #2
Welcome to TBN
I presume you have been regularly greasing the frt axle pivot points. Have you or your dealer checked steering pump pressure?
/ John deere 5720
Pivots good well maintained machine one pump does everything john deere have done $2500 labour just in testing. Am looking for a 5720 expert overseas that knows them backwords.
/ John deere 5720 #5
I am not familiar with the 5720 but could you answer a couple of questions.
1) does the steering feel change if you operate another function? I.e. lift the three point, operate one of the rear remotes to build pressure
2) Does the effort required to turn the steering wheel change while turning it slowly vs more rapidly?
/ John deere 5720
All functions work well. Steering is now heavy on the odd occasion it improves slightly for a couple of seconds but not good. Using the 3 point linkage does not change this. Have dead headed a remote while steering and nothing changes. Low revs high revs hot or cold is exactly the same. I kitted the load sensing and priority valves which is basically springs, there are no o rings that are important to operation. Sometimes turning the wheel rapidly is slightly easier than slowly. You only have to turn the wheel very slowly and it is tight. The valves I kitted I thoroughly inspected but am suspect there is something going on I can't see. I engaged the dealer for tech support but has cost me nothing but money. am worried I won't have this sorted now till after Christmas and I am already two weeks behind with work. I am asking for help overseas where there might be more of these around. I just can't keep replacing parts at my expense for nothing which is what the dealer wants.
/ John deere 5720 #7
Fred,
When you kitted the priority valve did you remove all the sliding spools to confirm they moved smoothly in the mating bore? In looking at the on-line parts breakdown I believe there is at least one possibly more orifices in the spools. Did you carefully inspect all of the orifices in the valve to make sure that one was not partially plugged?
Reason asking is that everything you are describing sounds like the steering unit is being starved of oil. Not sure what your dealer performed for tests but if you have the capabilities I would suggest installing a pressure gauge in the pressure line to the steering unit so that you can watch this pressure while steering. Not sure if Deere put test points in this area or not.
/ John deere 5720
Yes and have rechecked the spools. I agree about oil, am going to get my own test fittings even though john deere have tested every thing. Am concerned there is something wrong I can't see. There is a piston and spring between the sandwich which was replaced in the kit . The old piston had slight signs of wear but still moved freely. I don't know exacly what role this part does. I still think the problem is there but still living in hope that a jd expert might see my post.
/ John deere 5720 #9
Fred
Do you have the hydraulic schematic for your tractor? I am curious to see if the priority valve is an on demand type or continuous flow style.
On demand provides flow as needed to the steering circuit
Continuous flow provides a constant flow to the steering.
Like you say hopefully a Deere expert will see this
/ John deere 5720
No schematics are a secret. Has got load sensing port on the orbital unit.
/ John deere 5720 #11
If load sense line from steering orbital then most likely on demand system.
If you are going to get test equipment I would suggest looking at orbital inlet pressure and load sense at the same time. They should be within 200 - 300 PSI of each other while trying to steer. When not steering I would expect load sense to drop.
/ John deere 5720
Thanks for that i am going to be out of action for a while now with work. But i appreciate the advice. Christmas coming up does not help.
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2015 FORD TRANSIT CONNECT VAN (A66091)
2015 FORD TRANSIT...
2023 Kubota SVL75-2 (A64911)
2023 Kubota...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
2018 CHEVROLET IMPALA (A66091)
2018 CHEVROLET...
