John Deere 5525 Open Station electrical issue
   / John Deere 5525 Open Station electrical issue #1
Settle789
John Deere 5525 open station
John Deere 5525 4x4 w/loader
While dragging dirt with a scrape blade tractor shut off tried to restart dash powers up then nothing. Checked fuse box blown F1 20amp fuse
replaced fuse and it blew again. I disconnected the cold fuel sensor replaced fuse and it blew again. Found some corrosion and burn marks on the fuse box. Ordered new box 800.00, replaced and no change it blows F1 fuse. Checked wires and harness for damage found a hot wire cut by frame under the fuse box area that connected to the terminal block in the area next to the fuse box, repaired the wire. I am still having the same issue fuse blows. I have ordered a new key switch. My cell # is 478-234-1990 any help or ideas will be greatly appreciated My name is David.
   / John Deere 5525 Open Station electrical issue #2
Welcome to this forum
Install a test light in lieu of/or as a replacement for your tractors battery ground cable. Test light should illuminate. Then disconnect/reconnect wires 1 at a time until test light fails to illuminate. Last disconnected wire when test light fails to illuminate should be the problem wire/circuit.
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
Gravely Pro-Turn 152 Zero Turn Mower (A50860)
Gravely Pro-Turn...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
