John Deere 5525 Blowing fuse
   / John Deere 5525 Blowing fuse #21
Replaced the exact same part# that was described earlier in this thread. Temperature sensor/switch part#RE503242 , seems to be a common problem in several different models.
Yes that part has been failing since the late 90's. One would think JD engineers could determine a solution in 20+ years
   / John Deere 5525 Blowing fuse #22
OK, I'm getting around to replacing this switch on a 5045D 3-cyl. Everything is visible and looks easy but it's not. Take a look at the two pictures.
The radiator drain cock is blocked by the wire loom, so I loosened that and moved it out of the way. I wanted to attach a vinyl tubing to the drain outlet to catch some antifreeze in a jug, but it is near impossible to place a tube on there, either from above or below. The fluid splashes all over the place and I was afraid of the dog licking on it.
Where the switch/sensor is located it's easy to get a wrench on and loosen but there is a fuel line from the injector pump (return line?) in the way. Since the switch has the connector wiring attached the whole thing is swinging around and hitting the metal fuel line. I can't imagine screwing the new part in without busting something.
Have any of you replaced this item on the 2.9 liter turbo engine without running into these difficulties? This is a manufactured 2014 year model.
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
UNUSED FUTURE MINI EXCAVATOR LOG GRAPPLE (A51244)
UNUSED FUTURE MINI...
