john deere 550 dozer won"t start.
/ john deere 550 dozer won"t start. #1
museum quality
weld, maine
john deere 550 dozer 1987 / Kubota B2920 2010 / JD 260 skid steere 2003
I need some advice regarding an 87 jd dozer that wont start. when the ignition button is pushed it lightly whines and a slight puff of smoke comes from the starting selenoid. the batteries are fully charged and the connections are tight and clean. It has sat unused for a few months. any insights are appreciated. john
/ john deere 550 dozer won"t start. #2
:welcome:
When you say "ignition" I take it you mean a gasoline engine (because there is no electrical ignition system on a diesel engine). I assume it's been sitting outside, uncovered, in the weather. Time to drain the water from the solenoid and see if the slug is frozen (rusted). These should be lubed with dry graphite such as Lock-Eze. Grease or oil of any kind will thicken in the cold, and attract dirt and dust like a magnet.
Thanks for the reply. It is a diesel and there is no water in the solenoid. I took it apart and it was free an not rusted . could the starting motor be frozen?
/ john deere 550 dozer won"t start. #4
sounds like your starter is seized up bud
/ john deere 550 dozer won"t start. #5
When you say it whines is the starter even turning?
If it is turning but slow it could be a bad connection, I would check your ground cables and all of your connections from the battery to the starter.
If the starter is turning over good but not spinning the motor then yes your starter has set up. Might be able to smack it with a hammer and free it for a few starts but it will need to be replaced.
No its not turning at all.
When you say" starter" does that include the motor or just the solenoid starter switch? which is easy to replace.
/ john deere 550 dozer won"t start. #8
The starter would be the electrical motor that turns the motor over. The solenoid just controls if it gets voltage from the batteries. If the starter isn't turning at all I would check for voltage on the "load" side of the solenoid when the starter button is pushed. That would be the side that connects to the starter.
What was making the whining noise then? Usually all you might hear is a click if the solenoid is bad but not passing voltage.
I honestly couldnt tell you at the moment where the faint humming sound came from. there was the click from the relay and then smoke like that of a faded out match. at the solenoid ground terminal which was hot. it may have been old soot and grease that caused the smoke but not wire insulation. A new motor is $700. a "rebuild" I havent priced yet. Want to make sure that it is the problem before I remove it and potentially run into trouble there. Thanks. JG.
/ john deere 550 dozer won"t start. #10
There was the click from the relay and then smoke like that of a faded out match. at the solenoid ground terminal which was hot.
Do you have a relay that operates the starter solenoid primary current?
What do you mean by "solenoid ground terminal"?
I have never seen an isolated ground solenoid on a tractor.
The faint humming sound could have been the brushes on the comm or the starter windings.
Yes there is a relay that is functional and brings a live current to the solenoid. the solenoid has a large wire connection which is clearly hot with a large red wire coming in and one going out to the alternatorthe solenoid also has a small stud that(I think is neutral) which has two wires. one coming in from the relay and one going out to a stud mounted directly on the motor housing. the stud that leads to the motor housing was hot to the touch but was not hot on the motor housing stud.:)
/ john deere 550 dozer won"t start. #12
I believe that relay also supplies current to the alternator field windings, which control it's charge rate. There is no "neutral" it's all DC (Direct Current).
Positive = (+) Plus and Negative (ground) = (-) Minus. The small terminal on the solenoid is the (+) side of the solenoid motor windings that draw in the large high-current starter motor contacts, which are the two large terminals on the solenoid. The solenoid motor is grounded through the case to the engine block.
Assuming your batteries are of the correct amperage capacity, and all electrical connections are mechanically sound, I believe you are going to have to remove and disassemble the starter. We can go from there. The fact that the ground wire to the engine block was warm pretty much says everything is working OK except for the starter.
Thanks for the advise, I will take it off and also order a service manual on ebay. I never took the time to really learn about the mechanics of this beast and in a better economy I would hire it all out to a tech. and stick to doing what I know best. JG
/ john deere 550 dozer won"t start. #14
One last test you could try if you have a heavy duty set of jumper cables. Connect 1 side to the starter where the cable from the solenoid connects or the stud that goes from the solenoid to the starter. Then touch the other end to the positive terminal on the battery. Make sure you are only touching the points listed. If your starter is good it should spin over. If not then you will know for sure.
If your jumper cables aren't heavy enough they will get hot very quickly.
/ john deere 550 dozer won"t start. #15
I haven't worked on one of these in years, is it a 12 or 24 volt system, I can't remember, have you had the batteries out lately to be charged?
love the Reagan quote as well as the advice. I will certainly try that the next time I am with the machine. l Iooked at it today and dread the idea of taking the motor out. I can see two of the bolts holding it on but there is very little room to work them out as it now stands. The third bolt is underneath and may require the bottom plate to be removed.
The whole engine may need to be lifted out to get at them. Its all unchartered territory for me. Happy Thankgiving.
Im pretty sure its twelve volts and the batteries are new and live. In case this dozer needs to be transported to a shop, is there a way to get it jump started in order to get it on a truck without the starter/motor ?
/ john deere 550 dozer won"t start. #18
You can try a screwdriver between the small terminal on the solenoid and the large solenoid terminal with the battery cable on it. If that doesn't produce results then try the screwdriver between the two large terminals (watch out for arc flash). If this doesn't produce anything, then it can't be jumped.
Dumb question, but does the engine turn over by hand? Can you bar over the flywheel or get a socket on the front of the crankshaft?
/ john deere 550 dozer won"t start. #19
If you try what I put up with the jumper cables it should start if the starter motor is good. At least it would tell you if it is the starter or something like the solenoid.
Cat 312 Excavator (A62679)
Cat 312 Excavator...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
Great Plains 73290DH (A64126)
Great Plains...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
