John Deere 540b skidded
/ John Deere 540b skidded #1
Pete jd
qld
john Deere 540 b skidded
hi new to forum but we have a jd 540b skidded having trouble with hydrolics the main pump starts to chatter and we loose hydrolics and steering then we loose drive if you shut the machine down and wait a few minutes start it back up it runs fine for 5 or so minutes then looses hydrolics again any thoughts why this is happening thanks
/ John Deere 540b skidded #2
How long since sump screen(parts key 16 A or 16 B) has been checked/cleaned? How long since hyd filters were changed? Also a high pressure internal hyd leak or low pressure internal leak(trans pump circuit) can cause similar symptoms.
We have just done Trany and hyd filters and are going to clean the screens and see how that goes do you know if the screens are beside the Trany filter as the pick and work shop manual are a bit miss leading
/ John Deere 540b skidded #4
Yes screen is located inside of bottom of trans case. One needs to drain oil or insert the nozzle on hose of a running shop vac in hyd filler hole opening while checking screen
Ok thanks we will drop the oil and try that thank for you help
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
L6060 Kubota For Sale
(14) 24X48" FLOURESCENT CEILING LIGHTS (A64281)
(14) 24X48"...
Caterpillar 928F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 928F...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2003 Ford Ranger Pickup Truck (A61573)
2003 Ford Ranger...
