John deere 5400 , 1998
/ John deere 5400 , 1998 #1
Pierre Goulet
John deere 5400
Hello my name is Pierre
I live in Canada, Quebec
My John deere 5400, 1998 has a 12/12 hydraulic reverse transmission and when cold is still fine, but when hot loses power in front wheel drive only, it seems to lack hydraulic oil flow. for the transmission to work well. I spoke to the dealer and they have never seen that ???
Can someone help me ??
Thank you everyone and have a nice day
/ John deere 5400 , 1998 #2
Welcome to the forum. Quebec is a beautiful area,I’ve always had a great time there.
/ John deere 5400 , 1998 #3
Bonjour ami et bienvenue chez TBN d'Australie.
Profitez du site.
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
/ John deere 5400 , 1998 #4
Hi and welcome to the forum!
I'm going to move this thread over to our John Deere section.
:tractor:
thank you very much and hoping to find the information for my johndeere problem! Thank you
/ John deere 5400 , 1998 #6
I had a Deere 5520 once that had some strange things happen such as no brakes after the tractor warmed up. After a lot of angst and $500 in troubleshooting, it appears the remote levers were sticking just a tiny bit off center and causing the trans oil to overheat and cause problems. So I wiggled the remote levers and the problem went away and stayed away. The remote levers were just very slightly off center so no squealing and it took an hour for the oil to heat up and cause problems.
I have no idea if this is your issue but I have heard about others having similar odd problems like mine so it's worth a look. Our final diagnosis was with one of those laser pointer thermometers and we could see different parts of the transaxle at different temps. Definitely a Hail Mary stab at a cure but it worked.
/ John deere 5400 , 1998 #7
Pierre
Welcome to TBN
How are you determining that after tractor reaches operating temp. MFWD loses power?
MFWD is gear driven from trans to a drop box to front differential gears not hyd powered. Is it possible both rear & frt tires lose power?
Thank you , I check this
Hello!
No, my 5400 is fitted with a hydraulic reverse, so when the oil comes hot, that's when I lose traction power!
/ John deere 5400 , 1998 #10
I think hydraulic reverser clutch has a faulty seal therefore it can't hold enough pressure to keep clutch engaged when hyd oil warms up.
Tx Jim has just replied to a thread you have subscribed to entitled - John deere 5400 , 1998 - in the John Deere Owning/Operating forum of TractorByNet.com.
This thread is located at:
https://www.tractorbynet.com/forums...g/433403-john-deere-5400-1998-a-new-post.html
Here is the message that has just been posted:
To reply to this post, please visit: https://www.tractorbynet.com/forums...g/433403-john-deere-5400-1998-a-new-post.html
There may also be other replies, but you will not receive any more notifications until you visit the forum again.
Thank you,
Thank you,
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
Unverferth 432 (A64119)
Unverferth 432...
2012 International (A59230)
2012 International...
