John Deere 5320 with power reversal wants to roll when in “Park”
   / John Deere 5320 with power reversal wants to roll when in “Park” #1
Kmicah40
Butler, KY
John Deere 5320, ‘56 Ford 601 (been in family since new), 2010 Kubota 900RTV, Cub Cadet 2284, Cub Cadet 2064
My JD 5320 is gradually get worse when you put it into Park. Not an issue if you’re on mostly flat ground, but if on a slope and you put it in park most times it will start to roll. When it starts to roll a clicking sound can be heard. If I have to park on a slope I always use the front end loader bucket to raise the front end up enough that the tractor will not move. Was wondering if there is a mechanical adjustment that can be made or is this issue something that requires new parts to correct the problem. Also, is this problem something that requires a skilled mechanic to fix. Any help would be appreciated. Thanks Larry H
   / John Deere 5320 with power reversal wants to roll when in “Park” #3
@Kmicah40
Are you sure you’ve got shifter completely in park while stopped before you let off brakes ?
My 5101E will do this ratcheting clicking sound IF / When I don’t Properly do this method while parking on a hill.
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2014 DORSEY EXPANDABLE FLATBED (A59575)
2014 DORSEY...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
Sedan (A59231)
Sedan (A59231)
