2305 PTO - Be Careful
/ 2305 PTO - Be Careful #1
johnnydel29
Bronze Member
East of Albany, NY
JD 2305
Last summer, I posted a thread regarding MY PTO on my 2305 completely getting destroyed while brush mowing w/ a King Kutter 4' mower. I noticed that this happened to someone else w/ an LX-4 on this forum. Luckily, Deere completely reparied the PTO under warrenty. The total cost was a little over $4000.00.
I did some research and spoke to some very experienced Deere mechanics at different dealers and a few mentioned that you MUST be real careful when using the PTO on this machine. The reason is that the 2305 is is a very powerful machine with a very small body. In other words, it is a lawn mower on steriods. The gears in that PTO are small, compared to the larger machines. Therefore, the smaller gears become damaged easily, and over time they get worse (when you hit rocks). And one day, like that aweful warm summer evening when I was bush mowing, I hit a rock and those gears exploded before that shear pin even had a chance to break.
Even though the machine is repaired, I decided not to use the rear PTO much, just sparingly for brush mowing.
Now I have another problem. It is leaking hydro fluid where the rear crank shaft enters the housing. Deere picked it up and they are going to see what they can do to repair. This was my fear. Once these complex parts are taken apart and put back together, they can potentially be never the same. I am thinking, I may end up selling the machine in a few years.
Once agian, even though we feel like this little monster can do it all, be careful.
/ 2305 PTO - Be Careful #2
A slip clutch might be helpful.
/ 2305 PTO - Be Careful #3
The only PTO damage I have heard of on the JD2305 resulted from owner's not properly sizing the PTO shaft length. Too long of a shaft will push into the PTO housing, cracking the housing and possibly pushing far enough in to break the gears. Another possible suspect would be engaging the PTO at too high of an engine speed. Owner's manual states 1,500 rpms or less for PTO engagement.
Owner's manual has many sections of valuable reading (pto shaft sizing, 3ph hookup, etc.).
