John Deere 5300 - Best source for Service Manual
   / John Deere 5300 - Best source for Service Manual #12
You have downloaded the correct CTM (Component Technical Manual)#125. The regular Tech. Manual for the 5300 2.9 liter is TM1520
The info. you gave,
CD3029D242808 =
CD: Made in Saran, France.
3029= 3 cylinder , 029 displacement 2.9 Liter.
D= Naturally Aspirated.
242808= Sequential Serial Number.
David
   / John Deere 5300 - Best source for Service Manual #13
+1 to Dsgsr response. TM150 can be purchased at selectmanuals.com for 29.95 should you want it.
You have downloaded the correct CTM (Component Technical Manual)#125. The regular Tech. Manual for the 5300 2.9 liter is TM1520 The info. you gave, CD3029D242808 = CD: Made in Saran, France. 3029= 3 cylinder , 029 displacement 2.9 Liter. D= Naturally Aspirated. 242808= Sequential Serial Number. David
Thank you for explaining the breakdown of the engine data plate!
Excellent. Thank you for this information.
   / John Deere 5300 - Best source for Service Manual #16
I have a PDF of the Deere 5300 Tractor Technical manual that you're welcome to, if wanted shoot me your email
Joe
OK, I now have a PDF of the TM1520 manual.
But why, on the very first page, does it indicate that CTM8 is the correct engine manual, and not the CTM125?
   / John Deere 5300 - Best source for Service Manual #18
Charles, I'm not at home, so I can't read it, but I have the CTM8, it should be on the way to you. I can send it, just can't read it to see. Hope it helps
Joe
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
