John deere 5205
/ John deere 5205 #1
Laerry80
John Deere 5205
My Rear hydraulics won't go up and down. the level to operate the hydralics won't move, this all started when I tried swapping hoses to find out why my front loader wound tilt, It goes up and down fine but will not tilt. any help appreciated.
/ John deere 5205 #2
Try sending us more description of what is and is not happening. Not getting a clear picture of the problem, and what led up to your problem. Hope we can help.
/ John deere 5205
WHile doing these things the rear hydralics have locked up.
/ John deere 5205
Bucket goes up and down, but will not tilt. WHen I switch then hoses the bucket tilts but will not raise and lower, When I move the joy stick I can see the hoses flex and I hean a moan from the system. I replaced 2 of the quick couplers and no change. tractor runs fine, when I have the disconnects out, I can use the joystick to see the valve move back and forth in the control block. It acts like there is a block. This happened when I was piling up brush, I lowered the bucket, pushed some brush and it would not move after that, raises and lowers fine. Now the rear hyudralics have locked up
/ John deere 5205 #5
Best I can suggest is to get a pressure gauge that you can plug into the quick couplers and check for where you have pressure.
/ John deere 5205 #6
If the hoses budge when you move the levers, you have pressure building up that can't escape.
Replace couplers in pairs.
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
2013 FORD F-450XL SUPER DUTY DUMP TRUCK (A64277)
2013 FORD F-450XL...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
