John deere 5205
/ John deere 5205 #1
Laerry80
John Deere 5205
My Rear hydraulics won't go up and down. the level to operate the hydralics won't move, this all started when I tried swapping hoses to find out why my front loader wound tilt, It goes up and down fine but will not tilt. any help appreciated.
/ John deere 5205 #2
Try sending us more description of what is and is not happening. Not getting a clear picture of the problem, and what led up to your problem. Hope we can help.
/ John deere 5205
WHile doing these things the rear hydralics have locked up.
/ John deere 5205
Bucket goes up and down, but will not tilt. WHen I switch then hoses the bucket tilts but will not raise and lower, When I move the joy stick I can see the hoses flex and I hean a moan from the system. I replaced 2 of the quick couplers and no change. tractor runs fine, when I have the disconnects out, I can use the joystick to see the valve move back and forth in the control block. It acts like there is a block. This happened when I was piling up brush, I lowered the bucket, pushed some brush and it would not move after that, raises and lowers fine. Now the rear hyudralics have locked up
/ John deere 5205 #5
Best I can suggest is to get a pressure gauge that you can plug into the quick couplers and check for where you have pressure.
/ John deere 5205 #6
If the hoses budge when you move the levers, you have pressure building up that can't escape.
Replace couplers in pairs.
Metal Donkey (A65583)
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2007 Peterbilt 379 Acid Pumper Truck (A64194)
2007 Peterbilt 379...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
John Deere 6000-Series Tractor Loader Frames (A65640)
John Deere...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
