John Deere 5105 no electrical power
   / John Deere 5105 no electrical power #1
coyote77
Wittmann,Az
5105 John Deere
I have a 5105 John Deere, I have a problem with the electrical sys. I have no electric , I replaced battery, now key switch, but still have no lights or power of any kind. Real confussed. Oh I replaced every fuse in the fuse block too but still nothing. Hope someone has an idea.
   / John Deere 5105 no electrical power #2
I moved your post to the John Deere Owning and Operating section. Hopefully you should get some answers here.
Welcome to TBN.
Aaron Z
   / John Deere 5105 no electrical power #3
Re: coyote77
Hi Coyote77, welcome.
You may need to locate some master fuses/fusible links - they are sometimes buried in a harness somewhere - you need a shop manual, or access to somebody that knows that harness well, to locate these quickly.
Good Luck,
Rgds, D.
Thank you
Re: coyote77
Thanks I'll give it a look and let ya know what I found.
   / John Deere 5105 no electrical power #6
As suggested already take a look at the fuse link. Attached is a picture from JDparts what it looks like. It will be under the hood. On my 5210 which is similar to your tractor it is on the left side above the starter.
Did anything happen before the problem started?
  • 5105fuselink.pdf
Thank you, I checked the fuse link , it is intact . I have power to the ignition switch when the switch is unplugged. That seems strange to me but when plugged in there is no power. Thanks again.
I was backing up after just starting it. I had drained the water from fuel filter but forgot to prime the filter. It died so to save time I used starting spray . It then turned once an made a hard knock an when I hit the key again it blew a 25 amp fuse so I replaced all fuse's but still won't start an have no lights etc. Put in new battery also.
I also put in a new starter switch. Checked to see if motor was free. I turned it by hand it is free.
   / John Deere 5105 no electrical power #10
That's a typical symptom of a faulty battery ground connection
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
1996 Carolina Skiff 19ft Fishing Boat with Boat Trailer (A50324)
1996 Carolina...
