Oil & Fuel John Deere 5103
/ John Deere 5103 #1
WARTIGER45
Auburn
John Deere 5103
As I was cutting today I had my RPM's at 2200. Every now and then the engine would rise up to 2300-2400 rpms and stay there for about a minute and then slowly go back down. This happened about five times in an hour of cutting. Then after cutting I lowered the rpms all the down and it seemed as if it took a little bit longer to reach idle speed. Does anyone know what this could be? I just had the tractor serviced at a John Deere store.
PS The engine never overheated or sputtered.
/ John Deere 5103 #2
I wonder if there's any air in fuel system or if cold start advance is malfunctioning? You might try disconnecting cold start sensor for a trial. Governor is in the inj pump.
/ John Deere 5103
It seems like it would be more of air-like symptoms in the fuel line. Is the best way to eliiminate this problem to just drain fuel line at the fuel filter?
/ John Deere 5103 #4
Actually it's best to bleed all the way to the inj pump galley.
/ John Deere 5103
Will the air eventually bleed out on it own?
/ John Deere 5103 #6
Too a certain extent but air compresses in injectors easier unlike diesel fuel.
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
2018 Mitsubishi Eclipse SUV (A66738)
2018 Mitsubishi...
KENWORTH ROAD TRACTOR (A65053)
KENWORTH ROAD...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
