John Deere 5075M--things to look for
   / John Deere 5075M--things to look for #1
GreenTime
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I might be going to look at 2011 John Deere 5075M later today. Has cab, 16 speed transmission, and JD 563 loader, 1250 hours. Anything to really look at or check? I see earlier models like this one have a 5 cyl engine and later ones have a 3 cylinder. Any pros or cons on the engines. Thanks.
   / John Deere 5075M--things to look for #2
Where do you see the switch made to 3 cyl. ? TractorData shows the next model up had a 4 cyl, but don't see a 3 cyl.
What are you planning to use it for? Field work? Loader work?
I plan to use it for loader work, clearing brush and dead trees, and a finish mower.
Tractor data below shows 3 cyl engine used for 2015-17
Model years
Utility tractor
Series next: John Deere 5085M
more John Deere 5075M specifications...
Overview
Engine
Transmission
Dimensions
Photos
Tests
Engine Detail:
John Deere
turbocharged aftercooled diesel
3-cylinder
liquid-cooled inline
179 ci [2.9 L]
   / John Deere 5075M--things to look for #4
It seems engines are rarely problematic with most equipment. What I'd be looking at is maintenance history, previous type of use, clutch slippage, contaminated fluids , and if there's any noticeable wiring issues due to rodents or possibly water. Those tractors are pretty solid and it should be a good machine for you.
   / John Deere 5075M--things to look for #5
JD parts cat 13349 lists a 3 cyl block/liners for 5075M
   / John Deere 5075M--things to look for #6
Interesting...
2017 TROXEL 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 130...
2025 AGT 750 (A50123)
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
