John Deere 5075M--things to look for
   / John Deere 5075M--things to look for #1
GreenTime
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I might be going to look at 2011 John Deere 5075M later today. Has cab, 16 speed transmission, and JD 563 loader, 1250 hours. Anything to really look at or check? I see earlier models like this one have a 5 cyl engine and later ones have a 3 cylinder. Any pros or cons on the engines. Thanks.
   / John Deere 5075M--things to look for #2
Where do you see the switch made to 3 cyl. ? TractorData shows the next model up had a 4 cyl, but don't see a 3 cyl.
What are you planning to use it for? Field work? Loader work?
I plan to use it for loader work, clearing brush and dead trees, and a finish mower.
Tractor data below shows 3 cyl engine used for 2015-17
Model years
Utility tractor
Series next: John Deere 5085M
more John Deere 5075M specifications...
Overview
Engine
Transmission
Dimensions
Photos
Tests
Engine Detail:
John Deere
turbocharged aftercooled diesel
3-cylinder
liquid-cooled inline
179 ci [2.9 L]
   / John Deere 5075M--things to look for #4
It seems engines are rarely problematic with most equipment. What I'd be looking at is maintenance history, previous type of use, clutch slippage, contaminated fluids , and if there's any noticeable wiring issues due to rodents or possibly water. Those tractors are pretty solid and it should be a good machine for you.
   / John Deere 5075M--things to look for #5
JD parts cat 13349 lists a 3 cyl block/liners for 5075M
   / John Deere 5075M--things to look for #6
Interesting...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
Informational Lot - Shipping (A56435)
Informational Lot...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
