john deere 5055d 4 year old tractor
   / john deere 5055d 4 year old tractor #1
dw grigg
avery tx
john deere 5055d
I posted this in other threads ,thought I would repost here, I'm having issues with my 5055d 4 year old with 300 hours tractor.
first is gauge issues fuel and coolant, coolant will only reach left side of green and fuel at idle shows normal but when you increase rpm it drops to empty. ive cleaned where ground cable attaches. To me its still acting like a grounding issue , any ideas?
also front end loader tilt is out of sync, have added hydraulic oil with no change , any ideas.
also would like to thank this forum for it helped me fix a cranking problem I had with same tractor.
   / john deere 5055d 4 year old tractor #2
What do you mean when you state "front end loader tilt is out of sync"? On gauges not operating properly have you checked/cleaned/tightened instrument cluster grounds?
On the tilt with no attachment right side fully tilts then left, on gauges where are cluster grounds located?
   / john deere 5055d 4 year old tractor #4
On my 4400 with 430 loader which has the JD quick attach, it is the attachment (bucket, forks, etc) that mechanically connects the left and right bucket cylinders. Once the attachment is off, they are free to move independently. Is that what you are referring to?
   / john deere 5055d 4 year old tractor #5
I'm thinking, and responded to other thread the OP opened, that the bolt is sheared off on the rod that connects the two sides..
Shown circled in red (for a 553 FEL but similar to my 430 FEL), and this bolt will hold the two synched.
   / john deere 5055d 4 year old tractor #6
Interesting, maybe mine is sheared too. Hasn't bugged me enough to investigate!
Well when tractor was new they moved the same or just a little out of snyc ,now its way off, makes it hard to switch from bucket to hay fork
Really more worried bout the gauge issue
   / john deere 5055d 4 year old tractor #9
TR
I recall the same dilemma when the two sides were in synch in the beginning and then they moved independent of each other. Thought it was just a change in the looseness of the fit over time. Bugged me that they didn't move together but didn't figure it out at first.
Took awhile to notice that the pin was missing, so I replaced with a 1/4" bolt and lock nut. Now over the years, I probably shear that pin somehow about once a year. Think it may be when I drop the bucket and there is some resistance one side or the other.
But better that the pin shears, than something else gets bent.
Has nothing to do with fluid level tho. From reading other OP thread, may have over-filled your hyd fluid. Seems I read where 7 gallons were added? That would maybe be the total cap. in the system??
Cannot help with gauge dilemma.
Thanks ill check it
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2' Auger Extension (A50774)
2' Auger Extension...
