John Deere 494a Question
/ John Deere 494a Question #1
Adam JS
I recently purchased a John Deere 494a corn planter and I am looking at cutting it down to a 2 row. I was wondering if you would recommend I make it a 3 pt or keep it as hydrolic lift. If 3pt I need help with keeping the drive wheel(s) working, and if hydrolic I need to know what size hydrolic cylinder I need to use. I do not have any cylinder to use.
Any help is appreciated. Thank You
/ John Deere 494a Question #2
The 494A uses a standard 8" stroke agricultural cylinder with 1" diameter pins. Depending on the system pressure of your tractor's hydraulic system, a 2-1/2" or 3" bore cylinder should work fine. If your tractor has less than 1200 psi relief setting, consider a 3-1/2" bore cylinder.
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
2025 Wolverine TDB-11-72W 74in Track Duty Bucket Skid Steer Attachment (A60353)
2025 Wolverine...
2019 Chevrolet Cruze Sedan (A61569)
2019 Chevrolet...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
Kubota M6060 Tractor (A61166)
Kubota M6060...
LandHonor LHR-SL2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
