John Deere 4720 running rough
   / John Deere 4720 running rough #11
Not familiar with the 4720 but I think it is starving for fuel.
A couple of thoughts.
1. Is the filling cap vented? Try running it with the cap loose to see if it improves.
2. Is there a screen inside the tank on the fuel line that could be clogged?
3. Could there be trash in the tank that is restricting the suction line?
   / John Deere 4720 running rough #12
replace any rubber fuel lines, they can get cracks or pinholes that you can't notice. lastly, your injection pump may need to be serviced..
   / John Deere 4720 running rough #13
I have the same problem with my 4520 compact tractor. 2004. 1800 hours. I've done filters, air and fuel, cleaned tank and screen, fresh fuel, replaced fuel lines also the transfer or lift pump. I located a check valve in the return line and just got it. I will post if it fixes the problem.
   / John Deere 4720 running rough #14
I replaced the small pump and unfortunately no fix..It was 78* today...so fuel is not ice Ing
You mentioned the hand priming pump before, but did you replace the small lift pump that is mechanically driven from the side of the motor? It sounds like it is most definitely a fuel issue. Does the turbo seem to spool up normally under load?
   / John Deere 4720 running rough #15
Yes i did. It made no difference at all. Nothing I've done has made any difference. Hopefully i will be able to change the fuel check valve. I've been to 2 dealers and they haven't been able to help without me taking it to them.
   / John Deere 4720 running rough #16
Cranky>> the return check valve, was it on the top cover of the inj. pump.??
The problem "I'm" having helping is>> JD put several diff. inj. systems on the 4720 AND the 4520.!!
1 was a Stanadyne/RoosaMaster pump & the other is a PFR system where the pump sits in its own hole & is driven by a separate camshaft..
& they get diagnosed differently..
SO.. if the poster can ID the pumps on their machines.. I can probably answer the questions..
   / John Deere 4720 running rough #17
This man knows what he is talking about . Give him correct info . Do not rely on guesses , go with a man that knows his stuff .
   / John Deere 4720 running rough #18
did you pull the line off after the petcock and check for a good flow of fuel?.
   / John Deere 4720 running rough #20
I replaced the transfer pump on the side of the block, it runs off the camshaft. each injector has it's own pump that also runs off the cam it's under the valve cover
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 Isuzu NRR John Bean 700 Sewer Jetter Vacuum Truck (A49461)
2015 Isuzu NRR...
10 Ft Fork extensions (A50322)
10 Ft Fork...
