John Deere 4520 hydraulics for log splitter
   / John Deere 4520 hydraulics for log splitter
Will have a look where wire to switch runs. So I should be able to wire a switch into this?
   / John Deere 4520 hydraulics for log splitter #12
If you think about this, your clamshell switch probably has open-off/lock-closed..
So if you found the same 12v control wire, a switch could turn the solenoid valve on-off to power the A port to feed the log splitter .
So, when you want to use the clamshell, you use the reg switch.
When you want log splitter flow, us the on=off switch.
Make sure the log splitter switch is off when using the clamshell.
A toggle switch from off to on would work fine.
Thanks JJ. Will have a closer look on weekend and let you know how I go.
2015 Chevrolet 3500 HD (A50120)
2015 Chevrolet...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
New Holland C345 (A50120)
New Holland C345...
New Holland 474 Haybine (A50774)
New Holland 474...
