John Deere 4520 hydraulics for log splitter
   / John Deere 4520 hydraulics for log splitter
Will have a look where wire to switch runs. So I should be able to wire a switch into this?
   / John Deere 4520 hydraulics for log splitter #12
If you think about this, your clamshell switch probably has open-off/lock-closed..
So if you found the same 12v control wire, a switch could turn the solenoid valve on-off to power the A port to feed the log splitter .
So, when you want to use the clamshell, you use the reg switch.
When you want log splitter flow, us the on=off switch.
Make sure the log splitter switch is off when using the clamshell.
A toggle switch from off to on would work fine.
Thanks JJ. Will have a closer look on weekend and let you know how I go.
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
1240 (A50490)
1240 (A50490)
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
