John Deere 4520/Cab
   / John Deere 4520/Cab
ddivinia: Exactly what are extendable drag links. I did not notice them as an available option.
Nuru:
Thanks for your comment. Always worry about missing the price level.
   / John Deere 4520/Cab #12
tconners,
Darin D. is referring to the telescopic links, the end of the lower three point hitch arms slideout of a socket and move to allow easier hitching up to implements. When you back up they reseat themselves and lock in place. I have them myself and consider it a must have option, I would have said something before but missed the fact it wasn't on your option list.
I have those on my 5603...love em. I wish I had mentioned something to my salesman. I really did not find them to be an option.
I think I'll call him now and see if he can change the order.
Glad somebody mentioned it. Thanks.
   / John Deere 4520/Cab #14
Does it come with rear remotes or will you need them?
   / John Deere 4520/Cab #15
This would be a simple accessory add on, You would get the telescopic draft arms in a box, remove the standard arms and replace with the upgraded arms, save the standard ones in case one gets bent or breaks.
Gentlemen, thanks so much for pointing out to me that the telescoping arms were available on this model. I searched the options and found them, but can't imagine how I missed them when discussing the options with my dealer.
My dealer does these as a dealer installed item and they will exchange them when they receive the tractor.
Glad you guys are smarter than me.
Regards,
Terry Connors
   / John Deere 4520/Cab #17
Regards,
Terry Connors
No problem - you wont want to save the old ones because you will never want to use them after you have the telescopic ones.
D.
   / John Deere 4520/Cab #18
tconners, ddivinia,
Considering the fact that the arms are installed with clips similar to the implement end I don't see this as needed to be a dealer installed item. You paid for the first standard set that came with the tractor and you are now paying for the new telescopic arms. Much better for you to keep both sets of arms. If these arms had no value the dealer would not want them.
I agree with Darin that you will prefer the new arms features enough that you will likely not need the standard arms. If you ever needed them it is better to have them, and considering that using an IMatch setup the standard arms work great. If I am not mistaken, Darin did not care for the IMatch setup and I would hazard to guess he uses the telescopic link feature routinely. I on the otherhand use IMatch extensively and also have the telescopic links too, this enables me to easily hookup the odd implement I may aquire until I have a chance to do the IMatch conversion.
Backing up a 1250 lb boxblade behind either of my tractors it is good to know I have a spare set of arms available.
   / John Deere 4520/Cab #19
With imatch - not sure it is worth the extra money for the arms. I had imatch and got rid of it. It was too much of a hassle once I discovered the extendable links.
D.
In answer to some of the questions above, I did get one set of remotes which it comes with as a standard. I was going to get two, but found out that to add the second set required the addition of a diverter valve which increased the cost by another $1200 or so and decided I did not need to do that as I was only adding it as in "in case I need it in the future".
This, I was told, is also a dealer added item, so I could get it anytime I needed it for that same price.
Curiously, my dealer seems to like to add things themselves, this diverter and the telescoping links being examples.
I have a similar device to Imatch from Tractor supply shown here Quick Hitch, Cat. 1 - 0267563 | Tractor Supply Company
I tried to use it on some of my equipment and found that my 3 point hitch's on some of my items are not exactly standard. For example my mower (bush hog type) has an upper link connection point that comes nowhere close to what is required for the Quick Hitch, and so it became a nuisance and it was taken off and I have not used it in a couple of years.
Maybe now that I have this tractor, I will modify those devices so the quick hitch can be used again. I like the idea, but my equipment made it impractical.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 John Deere 6130M (A50120)
2016 John Deere...
Loader Bucket (A50322)
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2016 John Deere 6155M (A50120)
2016 John Deere...
