John Deere 4520/Cab
   / John Deere 4520/Cab #51
I've been thinking of buying a John Deere 4520, the dealer tells me i can't use a front mounted snow blower. Anyone know if this is correct?
4x20 series does not have a front blower option used with mid-PTO. As pointed out there is a blower that mounts on FEL and is hydraulically driven by a rear power pack (PTO driven pump). Erskine and others make similar systems as well as mechanically driven front blowers (power routed by joints and shaft from PTO to front). There's also several rear pull-type blowers (blower faces forward) where you drive over the snow first then blow it - sounds funny but owners swear by them. Not as good in huge dumps or plow banks obviously. Those are much cheaper than front options which are all circa $10k.
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
Kubota L35 4WD Tractor Loader Backhoe (A49461)
Kubota L35 4WD...
3in Poly Pipe (A49461)
