John Deere 4500
/ John Deere 4500 #1
brim0628
Southern Illinois
John Deere 4500
Afternoon everyone, I bought a 4500 months ago and haven't got more than 15 minutes in the seat. First the clutch went out a week after I bought it. Finally got around and dropped it off with a mechanic and he got it repaired. Hooked up the bushhog and drove out to the weedpatch and now my pto will not engage. I tested the switch and it appears to be ok. Is there a fuse or relay that I should check? Where exactly does the wiring lead to once it leaves the switch? I'd like to run down the wiring to make sure there isn't just a loose connection or broken wire. Thanks for any help, this thing is takin years off my life one problem at a time.
/ John Deere 4500 #2
The Deere 4500 is a kit tractor made buy Yanmar and sent to the Deere assembly facility.
The Yanmar US Series models align to you model. The Yanmar US40 has the 4TNE84 engine as well and the tech manual has a trouble shooting section for the PTO.
You can use Yandex OCR to translate the page images to English.
If the JD4500 has the Yanmar EG-UFO feature, then it's possible the PTO mode is not set right for running the brush mower. See page 72 attached. Wish I knew more of the more modern Yanmar/Deere UFO features. I only know the older system.
  • YANMAR US32 US36 US40 US46 US50 - US32R US36R US40R US46R US50R.pdf
