john deere 445 engine dies
/ john deere 445 engine dies #1
clop
Knox. IN.
john Deere 445
on my john deere 445 what would cause... when I push the forward pedal it kills the engine?
/ john deere 445 engine dies #2
First, welcome to TBN.
Have you checked the fuel filter?
What is the fuel condition... age, etc. that you know about?
Maybe we can sneak up on what the problem is.
/ john deere 445 engine dies #3
Is there a safety switch that could faulty on this model. Not sure how theseat switch interacts with the go pedals.
/ john deere 445 engine dies #4
Certainly seems to be a safety switch issue. Does the engine die as soon as the brake is released? there are 3 switches in the safety interlock system. The PTO Switch, The Brake Switch, and The Seat Switch. I own a 455 and have had problems with the seat switch. Remove the connector and reconnect, rapidly actuate and de-actuate the switch. If all else fails ohm out the switch to see if it has failed.
/ john deere 445 engine dies #5
Put a wire jumper in the switch connector and bypass it, that will confirm if switch is bad or not.
edc
:welcome: to TBN
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
VH4D Wisconsin Engine (A65640)
VH4D Wisconsin...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A59914)
2015 ALTEC AT200...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2020 Can-Am Commander XT 1000 R (A62679)
2020 Can-Am...
