John Deere 4410
/ John Deere 4410 #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I just bought a used 4410 with 800 hrs and the ehydro. My neighbor has the same tractor, but mine is slower than his. There are no error codes flasing. I read about calibrating the sensors, and I will try that. Since there are no error codes, how do I erase the current calibration? Do I need to just unplug the connectors and cycle the key on to erase current calibration?
/ John Deere 4410 #2
Can't answer the question, but am interested in the answer(s) you get.
Stop by the Deere dealer and ask that question. I'd expect them to be helpful and have an answer for you.
Another suggestion I have, would be to get the CD tech manual.
/ John Deere 4410
I have the tech manual. It shows the calibration and adjustment procedures.
/ John Deere 4410 #4
Try turning OFF the LoadMatch switch. I know my eHydro 4610 goes faster with the switch off. I only use it when I'm using the bucket or moving dirt with the box blade.
/ John Deere 4410 #5
After trying this, just make sure your neighbor's 4410 tires are the same rolling circumference as yours. Taller tires don't accelerate as quicker as shorter tires (Ag vs. R-4's, for example).
/ John Deere 4410
I just upgraded to R1's, but we did both have the same size R4's.
I tried the load match. Doesn't seem to make a difference wether it is on or off. Doesn't seem to affect any driving characteristics. I should try his to see if his changes wether it is on or off.
Should there be any noticeable differences if the oad match is on or off? Any way to test if it is working correctly?
/ John Deere 4410 #7
Are you telling us you just got this tractor and already you are drag racing the other kid in the neighborhood!!!! Next thing you know you'll have chains hooked up to the draw bars for a tractor pull!
/ John Deere 4410 #8
And Wheelies!!!
(Not that that is particularly difficult or desirable)
/ John Deere 4410 #9
I have done the drive controller recalibration and would not recomend it. It was very frustrating for me and did not fix my problem. Mine needed a potentiometer calibrated.
/ John Deere 4410 #10
DKs got it - turn off the load match, turn up the rpms and go man go.
I am also of the never recal a modern 4x series camp. lot easier to turn that switch.
Was at the Houston Live stock show last weekend - they have at least 5 4410s.
was walking looking at those babys thinking ....
how much trouble would I get in if I got on one and rode it up to out booth??
maybe act like I'm stopping to pick up trash every now and then:confused:
/ John Deere 4410
I tried the load match and it does not make a difference if it is on or off. Maybe the switch is bad? I think I was leaning towards the throttle tps calibration.
/ John Deere 4410 #12
At this point, it cannot hurt to try that calibration if you're comfortable with doing it.
I hope it works for you.
/ John Deere 4410 #13
Does the tractor run up to red line on the tach? Are your tires the same size as the other guys? Does the other guys run up to red line or beyond? Do both tractors weigh the same with operators on them? Why do you care if his is a little faster top end? They are not race cars! Line up drop the rag and before he gets ahead of you run him into the weeds!
/ John Deere 4410
So I tried the calibration with no results. I then changed all filters, screen and oil. No improvement. So I ordered the diagnostic connectors and checked the charge pressure. It was down to around 80 psi instead of the 170-190 psi. Since the charge pressure relief shim kit was $103, I added one SS 8mm x 1mm drilled out washer for $1 and the pressure is up to the 190 mark.
Of course what everyone is waiting for...... the speed increased substantially. Of course that not being good enough, we had a few cold ones and had to race them last weekend. Being I have the larger R1 tires and they are filled, he beat me off the line, but I got him on the top end. My status in the neighborhood is back on top, no dui's or wrecked tractors.
Thanks for the help.
/ John Deere 4410 #15
Could you take some pictures of where you hooked the connector up to and where the shims went?
/ John Deere 4410 #16
Oh.. oh.. NASCAR tractors! :D
AKfish
/ John Deere 4410 #17
AKfish
Yep...first we'll see the YouTube video...then we'll read all about it in the safety forum!!!
/ John Deere 4410
It's already back together, but there are plenty of pictures in the service manual that shows exactly what to do.
/ John Deere 4410 #19
Of course I never looked there!! Glad you got it fixed.
APPROX (12) REGENCY STAIR KITS (A64281)
APPROX (12)...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
2 Wheel Homemade Trailer (A64119)
2 Wheel Homemade...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
